Saltar al contenido principal
Squier Strat Guitar Pickups Replacement
Qué necesitas
  1. Squier Strat Guitar Pickups Replacement, Pickups: paso 1, imagen 1 de 3 Squier Strat Guitar Pickups Replacement, Pickups: paso 1, imagen 2 de 3 Squier Strat Guitar Pickups Replacement, Pickups: paso 1, imagen 3 de 3
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: paso 2, imagen 1 de 2 Squier Strat Guitar Pickups Replacement: paso 2, imagen 2 de 2
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: paso 3, imagen 1 de 3 Squier Strat Guitar Pickups Replacement: paso 3, imagen 2 de 3 Squier Strat Guitar Pickups Replacement: paso 3, imagen 3 de 3
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: paso 4, imagen 1 de 2 Squier Strat Guitar Pickups Replacement: paso 4, imagen 2 de 2
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: paso 5, imagen 1 de 2 Squier Strat Guitar Pickups Replacement: paso 5, imagen 2 de 2
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: paso 6, imagen 1 de 2 Squier Strat Guitar Pickups Replacement: paso 6, imagen 2 de 2
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: paso 7, imagen 1 de 2 Squier Strat Guitar Pickups Replacement: paso 7, imagen 2 de 2
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
Conclusión
4 personas más completaron esta guía.
Ion
Miembro Desde 09/29/15
479 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-5, Green Fall 2015 Miembro de Cal Poly, Team 10-5, Green Fall 2015
CPSU-GREEN-F15S10G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 75
Todo El Tiempo: 6,834
