Saltar al contenido principal
Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement
Qué necesitas
  1. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Front Panel: paso 1, imagen 1 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Front Panel: paso 1, imagen 2 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Front Panel: paso 1, imagen 3 de 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Main Panels: paso 2, imagen 1 de 2 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Main Panels: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Phillips #0 Screwdriver
    $5.49
    Comprar
  3. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 3, imagen 1 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 3, imagen 2 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 3, imagen 3 de 3
    Phillips #1 Screwdriver
    $5.49
    Comprar
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 4, imagen 1 de 1
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 5, imagen 1 de 2 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 5, imagen 2 de 2
    $5.49
    Comprar
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 6, imagen 1 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 6, imagen 2 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 6, imagen 3 de 3
    $5.49
    Comprar
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 7, imagen 1 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 7, imagen 2 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 7, imagen 3 de 3
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 8, imagen 1 de 2 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 8, imagen 2 de 2
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 9, imagen 1 de 1
    $5.49
    Comprar
  10. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 10, imagen 1 de 2 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 10, imagen 2 de 2
    $5.49
    Comprar
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 11, imagen 1 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 11, imagen 2 de 3 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement: paso 11, imagen 3 de 3
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
  12. Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Audio In/Audio Out Inputs: paso 12, imagen 1 de 2 Sony Xplod CDX-MP30 Audio In/Audio Out Inputs Replacement, Audio In/Audio Out Inputs: paso 12, imagen 2 de 2
    • To remove the Audio In/Audio Out inputs on the circuit board please refer to the iFixit soldering guide to assist you.
Conclusión
Una persona más ha completado esta guía.
Chao Chen
Miembro Desde 10/04/11
79 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-35, Amido Fall 2011 Miembro de Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 4,289
