Saltar al contenido principal
Sony Xperia Z2 Main Camera Replacement
Qué necesitas
Resumen del Video
  1. Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: paso 1, imagen 1 de 3 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: paso 1, imagen 2 de 3 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: paso 1, imagen 3 de 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Main Camera Replacement: paso 2, imagen 1 de 3 Sony Xperia Z2 Main Camera Replacement: paso 2, imagen 2 de 3 Sony Xperia Z2 Main Camera Replacement: paso 2, imagen 3 de 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Main Camera Replacement: paso 3, imagen 1 de 2 Sony Xperia Z2 Main Camera Replacement: paso 3, imagen 2 de 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Main Camera Replacement, Main Camera: paso 4, imagen 1 de 2 Sony Xperia Z2 Main Camera Replacement, Main Camera: paso 4, imagen 2 de 2
Conclusión
9 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,341 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,541 Guías creadas
7 comentarios
Where can I buy Spear main camera bucz my main camera is not functioning. Please help please... Please link me a website where I can buy it online.
Kushal maharjan - Contestar
search ebay for "sony xperia z2 camera", unbelievable right?
deftoner -
I crashed my sony z2 and after i fix the screen i but the camera and it's overheated and doesn't work.what i must do and change
chris kat - Contestar
I replied the comment to the other guy
deftoner -
My Camara get overheated too, and does not work, trying to replace it, where can I get it replace and how much does it go for thanks
Tripleboss - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 15
Todo El Tiempo: 9,125
