Saltar al contenido principal
Sony Xperia Z2 Earpiece Replacement
Qué necesitas
Resumen del Video
  1. Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: paso 1, imagen 1 de 3 Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: paso 1, imagen 2 de 3 Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: paso 1, imagen 3 de 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Earpiece Replacement: paso 2, imagen 1 de 3 Sony Xperia Z2 Earpiece Replacement: paso 2, imagen 2 de 3 Sony Xperia Z2 Earpiece Replacement: paso 2, imagen 3 de 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Earpiece Replacement: paso 3, imagen 1 de 2 Sony Xperia Z2 Earpiece Replacement: paso 3, imagen 2 de 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Earpiece Replacement, Battery: paso 4, imagen 1 de 3 Sony Xperia Z2 Earpiece Replacement, Battery: paso 4, imagen 2 de 3 Sony Xperia Z2 Earpiece Replacement, Battery: paso 4, imagen 3 de 3
  5. Sony Xperia Z2 Earpiece Replacement, Logic Board: paso 5, imagen 1 de 2 Sony Xperia Z2 Earpiece Replacement, Logic Board: paso 5, imagen 2 de 2
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
  6. Sony Xperia Z2 Earpiece Replacement: paso 6, imagen 1 de 3 Sony Xperia Z2 Earpiece Replacement: paso 6, imagen 2 de 3 Sony Xperia Z2 Earpiece Replacement: paso 6, imagen 3 de 3
  7. Sony Xperia Z2 Earpiece Replacement, Earpiece: paso 7, imagen 1 de 1
Conclusión
7 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,368 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,466 Guías creadas
3 comentarios
Would be nice with a comment on how to remove the earpiece.
Since the phone is waterresistance the headjack and earpiece are taped to the body which makes that you need to buy a new sparepart, but look out on ebay that you get a part with tape to it.
Claes - Contestar
After having done the removal of the earpiece you will have to, either buy a new adhesive for the earpice or a new earpiece. But be aware some spareparts are sold without adhesive.
Claes -
I accidentally torn apart one of the cables( vibrate cable:the brown one) I'm messed up! Vibration not working. What can I do? Where can I buy one of those cables? Please reply!
Mahtab - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 7,621
