Introducción
How to remove the Ethernet port from the Sony Vaio VGN-S260 laptop
Partes
No se requieren partes.
Flip the laptop over so the Vaio logo is facing down Locate the battery at the top and Find the release and unlock slides on the battery Slide the unlock tab to the unlock position
  • Flip the laptop over so the Vaio logo is facing down
  • Locate the battery at the top and Find the release and unlock slides on the battery
  • Slide the unlock tab to the unlock position
  • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab
Agregar Comentario
With the tabs still in the unlock position, slide the battery away from the main case. With the tabs still in the unlock position, slide the battery away from the main case.
  • With the tabs still in the unlock position, slide the battery away from the main case.
Agregar Comentario
Flip the computer over so the Vaio logo is facedown Unscrew the 2 screws next to the battery
  • Flip the computer over so the Vaio logo is facedown
  • Unscrew the 2 screws next to the battery
Agregar Comentario
Flip the computer over again so the Vaio logo is face up
  • Flip the computer over again so the Vaio logo is face up
  • Open the lid
Agregar Comentario
Press down on the outer gray shell around the keyboard Use the spudger to gently lift keyboard
  • Press down on the outer gray shell around the keyboard
  • Use the spudger to gently lift keyboard
  • Do not pull up the keyboard too far as it is attached to a ribbon underneath
There are 2 spring-held latches, one above the F4 and one above the F12. Push a latch up into the frame of the keyboard, then lift the keyboard gently in that area so the latch doesn't spring back. Then push the other latch and the keyboard will be released.
Yishai Sered - Contestar
Lift up lever underneath the ribbon to detach the keyboard. Lift up lever underneath the ribbon to detach the keyboard.
  • Lift up lever underneath the ribbon to detach the keyboard.
Agregar Comentario
Remove memory/wireless compartment cover
  • Remove memory/wireless compartment cover
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Flip so the Vaio Logo is face down Locate and remove a total of 8 screws on the bottom. Locate and remove a total of 8 screws on the bottom.
  • Flip so the Vaio Logo is face down
  • Locate and remove a total of 8 screws on the bottom.
There are 2 more screws on the bottom, one in the middle of the front next to the flash stick socket, and one under the memory door.
Find and remove 5 screws (they all have arrows next to them) from cover
  • Find and remove 5 screws (they all have arrows next to them) from cover
Agregar Comentario
Flip the laptop over so the Vaio logo is face up Use the spudger to pop up the upper casing Do not lift too much as the Uppercasing is attached to wires underneath
  • Flip the laptop over so the Vaio logo is face up
  • Use the spudger to pop up the upper casing
  • Do not lift too much as the Uppercasing is attached to wires underneath
  • Remove the wires that are attaching the uppercasing to the motherboard
There are also 5 screws from the top of the uppercasing.
The are 4 cables to remove: flat cable for the power and S buttons at top center; flat cable for the touchpad at bottom center; and 2 twisted pairs for the speakers.
The speaker cable socket is very delicate. If all you are getting at is the CPU or the hard drive, it may be enough to disconnect the flat cables and gently rotate the uppercasing shifting it left to allow access to the right-hand side with the CPU fan and the hard drive.
The top panel has cutouts that allow the cables to be disconnected before the top of the case is removed. The two flat cables are not clamped and can be pulled vertically out of their connectors. The delicate speaker cables are connected to the motherboard with plugs which can be gently levered up out of their sockets.
roberttrevellyan - Contestar
Remove the uppercasing
  • Remove the uppercasing
Agregar Comentario
Locate the screw holding the optical drive casing to the logic board
  • Locate the screw holding the optical drive casing to the logic board
  • Remove this screw
This screw is from the bottom, will not be there since you removed it to get the uppercasing.
However, there is a screw on the bottom right of the PC-CARD cage to remove.
Locate ribbon connecting optical drive case to logic board.
  • Locate ribbon connecting optical drive case to logic board.
  • Pop off the ribbon
  • Remove the metal PC-Card cage
Agregar Comentario
Locate the four screws holding the optical drive to the logic board
  • Locate the four screws holding the optical drive to the logic board
  • Remove the screws
Agregar Comentario
Locate brown locking tab above optical drive. Lift up on brown locking tab until ribbon is loose
  • Locate brown locking tab above optical drive.
  • Lift up on brown locking tab until ribbon is loose
  • Gently slide out and remove the optical drive from the computer
Agregar Comentario
Remove the blue ribbon from the Ethernet Circuit Board Remove the blue ribbon from the Ethernet Circuit Board
  • Remove the blue ribbon from the Ethernet Circuit Board
Agregar Comentario
Locate the screws near the Ethernet Port circuit board
  • Locate the screws near the Ethernet Port circuit board
  • Remove the screws.
Agregar Comentario
Locate the screws for the second ethernet circuit board
  • Locate the screws for the second ethernet circuit board
  • Remove the screws
Agregar Comentario
Remove the ethernet ports Remove the ethernet ports
  • Remove the ethernet ports
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jeffrey Bryan
Miembro Desde 20/04/10
544 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 16-4, Maness Spring 2010 Miembro de Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 3,063
