Introducción
If your keys appear to be broken, replacing the keyboard may be necessary.
To make sure the problem is with the keyboard, follow the trouble shooting guide.
When buying a new keyboard make sure it is compatible with PCG-F420.
CAUTION: Static electricity in your body can ruin your computer. Use an anti-static wristband.
The battery is located on the left side of the laptop as shown by the red circle.
  • The battery is located on the left side of the laptop as shown by the red circle.
Agregar Comentario
Pull the plastic cover down (indicated by the arrow) and then swing it upwards to reveal the battery compartment.
  • Pull the plastic cover down (indicated by the arrow) and then swing it upwards to reveal the battery compartment.
  • The battery can now be removed by pulling it.
Agregar Comentario
Use your Philips #00 screwdriver to unscrew the small screw counterclockwise.  This screw is for the audio/visual jacks on the left side of the laptop.
  • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
Agregar Comentario
This will unlock the cover between the keyboard and screen. Gently slide it to the right and lift up.  Be sure not to pull the keyboard hard as there are still wires attached.  These wires will be dealt with in the next step.
  • This will unlock the cover between the keyboard and screen. Gently slide it to the right and lift up. Be sure not to pull the keyboard hard as there are still wires attached. These wires will be dealt with in the next step.
Agregar Comentario
Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
  • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
  • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
Agregar Comentario
Find the green ribbon as indicated in the picture by the red circle.  This is what connects the keyboard to the motherboard.
  • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
Agregar Comentario
To unplug the ribbon cable, use a pair of tweezers to lift up the white bar near the connection to the motherboard. Only lift up the ribbon lightly to release ribbon from the motherboard.
  • To unplug the ribbon cable, use a pair of tweezers to lift up the white bar near the connection to the motherboard. Only lift up the ribbon lightly to release ribbon from the motherboard.
Agregar Comentario
Now, you can pull on the ribbon cable and it will detach from the motherboard. Now, you can pull on the ribbon cable and it will detach from the motherboard.
  • Now, you can pull on the ribbon cable and it will detach from the motherboard.
Agregar Comentario
Your keyboard is now safety detached.  Necessary repairs or replacements can be made from here.
  • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Andrew Quayle
Miembro Desde 15/04/10
35 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 29-77, Johann Spring 2010 Miembro de Cal Poly, Team 29-77, Johann Spring 2010
CPSU-JOHANN-S10S29G77
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,295
