Introducción
The purpose of this guidelines is to show user how to remove the DVD drive and reinstall a new one. Please follow instructions carefully for successful results.
These are the parts of the laptop that you will need to know about: Power panel: shown in photo 1. Power panel ribbon: located on the back of the power panel. This is the white ribbon in photo 2.
  • These are the parts of the laptop that you will need to know about:
    • Power panel: shown in photo 1.
    • Power panel ribbon: located on the back of the power panel. This is the white ribbon in photo 2.
    • Keyboard and keyboard ribbon. Ribbon is located within the red box highlighter in photo 3.
Agregar Comentario
Keep laptop sitting on table to avoid dropping it and causing irreparable damage. Open Laptop. Using a Phillips screwdriver, remove power panel screw located on the left side of the laptop. See red box in photo for screw location.
  • Keep laptop sitting on table to avoid dropping it and causing irreparable damage.
  • Open Laptop.
  • Using a Phillips screwdriver, remove power panel screw located on the left side of the laptop. See red box in photo for screw location.
  • To remove power panel, slide it to the right and gently lift upwards.
  • Gently detach power panel ribbon from the motherboard by sliding the ribbon out of plastic connector keeping it attached to power panel.
Agregar Comentario
Detach keyboard ribbon cable from motherboard. Lift top latch of plastic connection piece and ribbon cable will be able to slide out. Slide keyboard out. Photo 3 shows the DVD drive once the power panel and keyboard tray have been removed.
  • Detach keyboard ribbon cable from motherboard.
    • Lift top latch of plastic connection piece and ribbon cable will be able to slide out. Slide keyboard out.
      • Photo 3 shows the DVD drive once the power panel and keyboard tray have been removed.
Agregar Comentario
Remove first screw from the DVD drive with Philips screwdriver. Refer to photo 1 for screw's location. Remove second screw from the DVD drive with Philips screwdriver. Refer to photo for screw's location. Remove second screw from the DVD drive with Philips screwdriver. Refer to photo for screw's location.
  • Remove first screw from the DVD drive with Philips screwdriver. Refer to photo 1 for screw's location.
  • Remove second screw from the DVD drive with Philips screwdriver. Refer to photo for screw's location.
Agregar Comentario
Gently detach ribbon cable from the DVD drive. Pull the hard part of the cable straight back from the DVD drive. Remove DVD drive from laptop by gently sliding it out through the outside of the laptop. Remove DVD drive from laptop by gently sliding it out through the outside of the laptop.
  • Gently detach ribbon cable from the DVD drive. Pull the hard part of the cable straight back from the DVD drive.
  • Remove DVD drive from laptop by gently sliding it out through the outside of the laptop.
Agregar Comentario
Congratulations! You have just successfully removed the DVD drive. You are now ready to install new DVD drive. Congratulations! You have just successfully removed the DVD drive. You are now ready to install new DVD drive.
  • Congratulations! You have just successfully removed the DVD drive. You are now ready to install new DVD drive.
Agregar Comentario
Gently slide DVD drive into laptop. If the drive gets stuck while sliding in, gently push down on metal bay below DVD drive to allow DVD drive to slide over. Reattach ribbon cable to DVD drive. Replace both DVD drive screws. See photo for reference.
  • Gently slide DVD drive into laptop. If the drive gets stuck while sliding in, gently push down on metal bay below DVD drive to allow DVD drive to slide over.
  • Reattach ribbon cable to DVD drive.
  • Replace both DVD drive screws. See photo for reference.
Agregar Comentario
Reattach keyboard ribbon cable to motherboard. Slide ribbon cable into plastic connector and then push top down to latch. Slide keyboard back into place. Reattach power panel ribbon cable to motherboard. Slide power panel into place. Reattach power panel ribbon cable to motherboard. Slide power panel into place.
  • Reattach keyboard ribbon cable to motherboard. Slide ribbon cable into plastic connector and then push top down to latch. Slide keyboard back into place.
  • Reattach power panel ribbon cable to motherboard. Slide power panel into place.
Agregar Comentario
Replace power panel side screw. Congratulations! The installation is now complete!
  • Replace power panel side screw.
  • Congratulations! The installation is now complete!
Agregar Comentario
Linea de Meta
Genaro Sanchez
Miembro Desde 14/04/10
46 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 18-68, Johann Spring 2010 Miembro de Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 4,733
