Saltar al contenido principal
Sony Vaio PCG-981L Battery Replacement
  1. Sony Vaio PCG-981L Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting, be sure the device is turned off and disconnected from any power cords.
    • Place the device on a flat surface.
  2. Sony Vaio PCG-981L Battery Replacement: paso 2, imagen 1 de 1
    • Rotate the device 90° counterclockwise until the battery cover is in front of you.
    • The battery cover is located in the lower right side of the device in this new orientation.
  3. Sony Vaio PCG-981L Battery Replacement: paso 3, imagen 1 de 1
    • Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
    • In this new orientation, the battery cover is located on the left side.
  4. Sony Vaio PCG-981L Battery Replacement: paso 4, imagen 1 de 1
    • To remove the battery cover, use your hands to slide it upwards.
  5. Sony Vaio PCG-981L Battery Replacement: paso 5, imagen 1 de 3 Sony Vaio PCG-981L Battery Replacement: paso 5, imagen 2 de 3 Sony Vaio PCG-981L Battery Replacement: paso 5, imagen 3 de 3
    • Once lifted, the battery cover should flip open.
    • Now, carefully remove the battery from the device.
  6. Sony Vaio PCG-981L Battery Replacement: paso 6, imagen 1 de 2 Sony Vaio PCG-981L Battery Replacement: paso 6, imagen 2 de 2
    • Now, the battery should be completely removed from the device.
    • Be sure to dispose of the old battery properly and then you are finished.
Conclusión
Enjoy your new battery.
Equipo
Cal Poly, Team 18-68, Johann Spring 2010 Miembro de Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 16
Todo El Tiempo: 3,814
