Introducción
This guide will help you disassemble your Sony Vaio PCG-7A2L Laptop in order to replace or remove the optical drive.
Lay the closed laptop on its screen so the bottom is facing towards you.
  • Lay the closed laptop on its screen so the bottom is facing towards you.
Agregar Comentario
Push both latches towards the center of the battery.
  • Push both latches towards the center of the battery.
Agregar Comentario
Revome the battery by pushing it away from the laptop. Set the battery away from the laptop.
  • Revome the battery by pushing it away from the laptop.
  • Set the battery away from the laptop.
Agregar Comentario
With the bottom of the laptop facing up, locate the RAM cover. The RAM is covered by the panel with four columns of vents.
  • With the bottom of the laptop facing up, locate the RAM cover.
  • The RAM is covered by the panel with four columns of vents.
  • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
Agregar Comentario
Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters) Once the panel is out of its locked position, it can be lifted out without any resistance. Once the panel is out of its locked position, it can be lifted out without any resistance.
  • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
  • Once the panel is out of its locked position, it can be lifted out without any resistance.
Agregar Comentario
Locate and remove the screw (Length: 7.7mm) for the hard drive cover. Slide the cover until it is free from the laptop case. Lift the cover to remove.
  • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
  • Slide the cover until it is free from the laptop case.
  • Lift the cover to remove.
Agregar Comentario
Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place. Using the tab on the tray, slide the Hard Drive away from the main body of the laptop. The Hard Drive should now be disconnected.
  • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
  • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
  • The Hard Drive should now be disconnected.
  • Lift the drive out with the tab on the tray.
Agregar Comentario
Locate the screws highlighted here.  There are 16 total.
  • Locate the screws highlighted here. There are 16 total.
  • Using a Phillips #0 screwdriver, remove the screws (Length: 6.8mm) and place them on a tray for later use.
Agregar Comentario
Before you proceed, make sure you pay special attention to the way the small plastic part that covers the radiator fins is held in place.  You will need to know how it attaches when you reassemble the laptop. You do not need to actually remove the part at this time.  It is held in place by the rest of the back cover and will fall off when back cover is removed in the next step. You do not need to actually remove the part at this time.  It is held in place by the rest of the back cover and will fall off when back cover is removed in the next step.
  • Before you proceed, make sure you pay special attention to the way the small plastic part that covers the radiator fins is held in place. You will need to know how it attaches when you reassemble the laptop.
  • You do not need to actually remove the part at this time. It is held in place by the rest of the back cover and will fall off when back cover is removed in the next step.
Agregar Comentario
After removing the screws, use your fingers to lift the back cover off the laptop. After removing the screws, use your fingers to lift the back cover off the laptop.
  • After removing the screws, use your fingers to lift the back cover off the laptop.
Agregar Comentario
Remove the back cover and place it somewhere safe so you can locate it later.
  • Remove the back cover and place it somewhere safe so you can locate it later.
Agregar Comentario
Locate and remove the screws (Length: 5.8mm) affixing the drive to the laptop frame. Gently slide the drive away from the body of the laptop until it is disconnected. Lift the drive out.
  • Locate and remove the screws (Length: 5.8mm) affixing the drive to the laptop frame.
  • Gently slide the drive away from the body of the laptop until it is disconnected.
  • Lift the drive out.
Agregar Comentario
Once the drive is removed from the main body of the laptop, you will need to remove the two connecting brackets. Locate the screws for the brackets. There should be one on each side of the drive and two on the end that connects to the computer. Unscrew and remove the brackets.
  • Once the drive is removed from the main body of the laptop, you will need to remove the two connecting brackets.
  • Locate the screws for the brackets. There should be one on each side of the drive and two on the end that connects to the computer.
  • Unscrew and remove the brackets.
Agregar Comentario
The last step is to remove the tray cover (the part that is exposed when the tray is closed).
  • The last step is to remove the tray cover (the part that is exposed when the tray is closed).
  • The next two steps are not necessary if your replacement drive came with a tray cover already attached.
  • Open the drive by poking a straightened paper clip in the small hole on the front of the tray cover.
Agregar Comentario
Locate the two tabs on the inside of the cover that hold it in place. Use a spudger or similar tool to unclip each tab. The cover should come right off. Use a spudger or similar tool to unclip each tab. The cover should come right off.
  • Locate the two tabs on the inside of the cover that hold it in place.
  • Use a spudger or similar tool to unclip each tab. The cover should come right off.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Matt McCarty
Miembro Desde 15/04/10
220 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 24-32, Regan Spring 2010 Miembro de Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Miembros
8 Guías creadas
To Clarify: Will the Vaio be usable w/o the optical drive once it has been reassembled?
Rock - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 6
Últimos 30 Días: 34
Todo El Tiempo: 8,337
