Introducción
The processor can be replaced with an identical or compatible processor. Please double check to see if the new processor is compatible with this laptop.
Qué necesitas
Power off the laptop.
Unplug the charging cable and any other cables plugged into the laptop.
Turn the laptop over so that the back panel is facing upwards.
Remove all the 8mm Phillips #1 screws on the backside of the laptop.
There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
There are three 3mm screws under the optical drives that also need to be taken out.
Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
Locate and remove the four 5.3 mm Phillips #1 screws on the top of the fan.
Locate the locking mechanism for the processor.
Using a flathead screwdriver, rotate the mechanism to the unlocked position.
To reassemble your device, follow these instructions in reverse order. In addition, please remember to remove and replace the old thermal paste. For instructions, please refer to this guide.
4 personas más completaron esta guía.
