Partes
No se requieren partes.
Flip the computer so that the bottom is facing up.
  • Flip the computer so that the bottom is facing up.
  • Look to the long edge where the computer screen is hinged and find the "release slide". It is located at the top left corner of the square indent.
Agregar Comentario
Use your finger to slide the release to the left.
  • Use your finger to slide the release to the left.
Agregar Comentario
While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide  it out. While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide  it out.
  • While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide it out.
Agregar Comentario
Take out the screw in the center of the computer.
  • Take out the screw in the center of the computer.
Agregar Comentario
Flip the computer right side up.
  • Flip the computer right side up.
  • Open screen so that keyboard is visible.
Agregar Comentario
Use a plastic opening tool to gently lift the keyboard at a corner. Make sure you get below the keyboard itself and not just the keys.
  • Use a plastic opening tool to gently lift the keyboard at a corner.
  • Make sure you get below the keyboard itself and not just the keys.
  • Slide the tool around the perimeter of the keyboard and it will start to lift.
Agregar Comentario
Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer. Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
  • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
Agregar Comentario
Locate the ribbon cord behind the keyboard. Locate a brown clamp attaching the keyboard to the computer. Use a plastic opening tool to lift the clamp and release the cable.
  • Locate the ribbon cord behind the keyboard.
  • Locate a brown clamp attaching the keyboard to the computer.
  • Use a plastic opening tool to lift the clamp and release the cable.
  • Now the keyboard can be pulled away entirely.
Agregar Comentario
Take out the screw under the keyboard.
  • Take out the screw under the keyboard.
Agregar Comentario
Flip computer over and remove the 6 screws.
  • Flip computer over and remove the 6 screws.
Agregar Comentario
Flip computer over again and unclip the plastic cover.
  • Flip computer over again and unclip the plastic cover.
  • Do not be afraid to be rough, since the cover is hard to remove.
  • Be sure to remove the case slowly and unclip any ribbon cords that are attached.
Agregar Comentario
Locate the hard drive disk. The hard drive disk will be covered by a shiny lid. Unscrew the lid with a #00 Phillips Head Screwdriver.
  • Locate the hard drive disk. The hard drive disk will be covered by a shiny lid.
  • Unscrew the lid with a #00 Phillips Head Screwdriver.
  • There are 3 screws holding it in.
  • Grab the lid by one corner and pull off the lid.
Agregar Comentario
Find the brown clip attached to the hard disk drive on the side facing the optical disk drive.
  • Find the brown clip attached to the hard disk drive on the side facing the optical disk drive.
  • Carefully pull out the brown clip with your fingers.
Agregar Comentario
Hold the hard disk drive on the side where the brown clip was attached and lift it upwards to pull it out.
  • Hold the hard disk drive on the side where the brown clip was attached and lift it upwards to pull it out.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Jenny Wang
Miembro Desde 03/04/12
92 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 5-3, Forte Spring 2012 Miembro de Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Miembros
6 Guías creadas
Muito bom, me ajudou muito...
lordsan32 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 27
Últimos 30 Días: 101
Todo El Tiempo: 13,769
