Introducción
This guide will inform readers on how to safely remove the fan of the Sony VAIO VPC-EB33FM laptop for replacement.
If the laptop isn't turned off, then do so by holding down the power button. Turn the laptop onto its backside.
  • If the laptop isn't turned off, then do so by holding down the power button.
  • Turn the laptop onto its backside.
Agregar Comentario
Locate the battery below the screen attachment.
  • Locate the battery below the screen attachment.
  • The battery is shaped as a long rectangle with rounded edges.
Agregar Comentario
Press into the release button while holding the unlock button in position.
  • Press into the release button while holding the unlock button in position.
Agregar Comentario
Lift the battery out at the notch while holding the release button. Lift the battery out at the notch while holding the release button.
  • Lift the battery out at the notch while holding the release button.
Agregar Comentario
Remove all charge from the laptop by holding down the power button for at least 5 seconds.
  • Remove all charge from the laptop by holding down the power button for at least 5 seconds.
Agregar Comentario
Turn laptop onto its backside and locate the hard drive cover panel. Turn laptop onto its backside and locate the hard drive cover panel.
  • Turn laptop onto its backside and locate the hard drive cover panel.
Agregar Comentario
Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel. Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
  • Use a Phillips #00 screwdriver to remove the two 7.75-mm cover screws on the bottom corners of the panel.
Agregar Comentario
Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off. You may need to use your other hand to safely remove the panel. You can also use a spudger for this step
  • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
  • You may need to use your other hand to safely remove the panel.
  • You can also use a spudger for this step
Agregar Comentario
The hard drive should now be exposed.
  • The hard drive should now be exposed.
  • Remove the two remaining 7.75-mm screws using the Phillips #00 screwdriver.
Agregar Comentario
Grab the tab between your thumb and index finger.
  • Grab the tab between your thumb and index finger.
  • Hold the hard drive securely in a horizontal position using your other hand.
  • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
  • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
Agregar Comentario
While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle. Pull the hard drive out.
  • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
  • Pull the hard drive out.
Agregar Comentario
If you need to remove the bracket from the hard drive, follow the next few steps: Remove the two 3.67-mm screws from either side of the bracket with a Phillips #00 screwdriver.
  • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.67-mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
Agregar Comentario
Remove the one screw with a Phillips #00 screwdriver. The screw cannot be removed from the RAM casing cover. The screw cannot be removed from the RAM casing cover.
  • Remove the one screw with a Phillips #00 screwdriver.
  • The screw cannot be removed from the RAM casing cover.
Agregar Comentario
Pull the two retaining arms away from the center of the RAM chip. The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  • Pull the two retaining arms away from the center of the RAM chip.
  • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
Agregar Comentario
Pull the RAM stick out of its socket. To remove the second stick of RAM, repeat steps six and seven. When installing RAM, make sure sticks are firmly in place or the computer will not register them.
  • Pull the RAM stick out of its socket.
  • To remove the second stick of RAM, repeat steps six and seven.
  • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
Agregar Comentario
Remove the following 16 screws securing the back cover using a Phillips #00 screwdriver:
  • Remove the following 16 screws securing the back cover using a Phillips #00 screwdriver:
    • Two 3.8-mm screws
    • Two 8.9-mm screws
    • Twelve 7.75-mm screws
Agregar Comentario
Check to make sure all the screws have been removed.
  • Check to make sure all the screws have been removed.
  • Using both hands, separate the back cover by lifting from the back and working around the perimeter to release tabs.
Agregar Comentario
Locate the fan and the processor attachment. Locate the fan and the processor attachment.
  • Locate the fan and the processor attachment.
Agregar Comentario
Using a Phillips #00 screwdriver, remove the top four 3.88-mm fan screws.
  • Using a Phillips #00 screwdriver, remove the top four 3.88-mm fan screws.
Agregar Comentario
Remove the two 5.7-mm screws located at the base of the fan, using a Phillips #00 screwdriver.
  • Remove the two 5.7-mm screws located at the base of the fan, using a Phillips #00 screwdriver.
Agregar Comentario
Pull back the tape located on the far side of the fan.
  • Pull back the tape located on the far side of the fan.
Agregar Comentario
Remove the wired connection between the fan and the copper wire using metal tweezers.
  • Remove the wired connection between the fan and the copper wire using metal tweezers.
    • Do not to pull on the wires directly or it will damage the connection between the fan and the laptop.
Agregar Comentario
Remove the four 5.65-mm screws on the processor corners using a Phillips #00 screwdriver.
  • Remove the four 5.65-mm screws on the processor corners using a Phillips #00 screwdriver.
Agregar Comentario
You are now ready to remove fan and processor connection Position thumbs and index fingers close to processor and lift up on the copper wire, while applying slight downward pressure on the motherboard with remaining fingers.
  • You are now ready to remove fan and processor connection
  • Position thumbs and index fingers close to processor and lift up on the copper wire, while applying slight downward pressure on the motherboard with remaining fingers.
  • If there is thermal paste between the processor and the fan attachment, increased force will be required to detach the fan.
Agregar Comentario
Conclusión
11 personas más completaron esta guía.
Kevin
Miembro Desde 11/01/13
466 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-39, Regan Winter 2013 Miembro de Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Miembros
6 Guías creadas
I don't know who you are, but you are a god to me!! Laptop is fixed and humming along like it is supposed to!!
Great and easy directions, thank you from the bottom of my heart....and the bottom of my husbands wallet!
creaper126 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 15
Últimos 30 Días: 94
Todo El Tiempo: 17,120
