Saltar al contenido principal
Sony VAIO PCG-933A Thermal Paste Replacement
Qué necesitas
  1. Sony VAIO PCG-933A Thermal Paste Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO PCG-933A Thermal Paste Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Thermal Paste Replacement: paso 2, imagen 1 de 3 Sony VAIO PCG-933A Thermal Paste Replacement: paso 2, imagen 2 de 3 Sony VAIO PCG-933A Thermal Paste Replacement: paso 2, imagen 3 de 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Thermal Paste Replacement, Keyboard: paso 3, imagen 1 de 1
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
  4. Sony VAIO PCG-933A Thermal Paste Replacement: paso 4, imagen 1 de 2 Sony VAIO PCG-933A Thermal Paste Replacement: paso 4, imagen 2 de 2
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
  5. Sony VAIO PCG-933A Thermal Paste Replacement: paso 5, imagen 1 de 1
    • Flip the computer so the key board is facing up.
  6. Sony VAIO PCG-933A Thermal Paste Replacement: paso 6, imagen 1 de 3 Sony VAIO PCG-933A Thermal Paste Replacement: paso 6, imagen 2 de 3 Sony VAIO PCG-933A Thermal Paste Replacement: paso 6, imagen 3 de 3
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
  7. Sony VAIO PCG-933A Thermal Paste Replacement: paso 7, imagen 1 de 3 Sony VAIO PCG-933A Thermal Paste Replacement: paso 7, imagen 2 de 3 Sony VAIO PCG-933A Thermal Paste Replacement: paso 7, imagen 3 de 3
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
  8. Sony VAIO PCG-933A Thermal Paste Replacement, Thermal Paste: paso 8, imagen 1 de 2 Sony VAIO PCG-933A Thermal Paste Replacement, Thermal Paste: paso 8, imagen 2 de 2
    • Remove the two 4mm Phillips screws in the center of the computer located on each side of the copper electrical strip.
  9. Sony VAIO PCG-933A Thermal Paste Replacement: paso 9, imagen 1 de 3 Sony VAIO PCG-933A Thermal Paste Replacement: paso 9, imagen 2 de 3 Sony VAIO PCG-933A Thermal Paste Replacement: paso 9, imagen 3 de 3
    • Remove the four 4mm Phillips screws around the hard drive cage.
    • WARNING: DVD drive is now loose as well.
    • Lift hard drive cage straight up.
    • Carefully disconnect the copper strip to pull out the hard drive.
  10. Sony VAIO PCG-933A Thermal Paste Replacement: paso 10, imagen 1 de 2 Sony VAIO PCG-933A Thermal Paste Replacement: paso 10, imagen 2 de 2
    • With the hard drive removed, unscrew the four 6mm brass colored, Phillips screws under the hard drive cage
    • This will allow you to remove the hard drive mounting bracket
  11. Sony VAIO PCG-933A Thermal Paste Replacement: paso 11, imagen 1 de 1
    • Remove the three 6mm brass colored, Phillips screws that hold the fan cage in place.
  12. Sony VAIO PCG-933A Thermal Paste Replacement: paso 12, imagen 1 de 2 Sony VAIO PCG-933A Thermal Paste Replacement: paso 12, imagen 2 de 2
    • Remove the two 4mm black Phillips screws shown here.
    • Remove the 18mm silver Phillips screw shown here.
    • Now remove the silver tab.
  13. Sony VAIO PCG-933A Thermal Paste Replacement: paso 13, imagen 1 de 2 Sony VAIO PCG-933A Thermal Paste Replacement: paso 13, imagen 2 de 2
    • Remove the blue and red fan power cords.
  14. Sony VAIO PCG-933A Thermal Paste Replacement: paso 14, imagen 1 de 2 Sony VAIO PCG-933A Thermal Paste Replacement: paso 14, imagen 2 de 2
    • Carefully pull up and out on the metal heat sink and fan bracket.
    • You should be able to see the thermal paste.
  15. Sony VAIO PCG-933A Thermal Paste Replacement: paso 15, imagen 1 de 1
    • To remove thermal paste thoroughly, put isopropyl alcohol (70% or greater) on a paper towel and wipe thermal paste off. Some force may be required.
    • Apply new thermal paste to CPU.
Conclusión
Sara Lillard
Miembro Desde 04/11/11
165 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 12-36, Maness Spring 2011 Miembro de Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 4,109
