Introducción
This guide shows the repairing and replacing of the keyboard.
Partes
No se requieren partes.
Turn the laptop upside down The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  • Turn the laptop upside down
  • The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Agregar Comentario
As shown by the arrow, slide the plastic cover up and then pull out and downwards. You should now be able to pull the battery out. You should now be able to pull the battery out.
  • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
  • You should now be able to pull the battery out.
Agregar Comentario
Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
  • Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the 4mm Phillips screw on the right rear side of the laptop next to the audio ports. This will release the speaker grille.
  • Remove the 4mm Phillips screw on the right rear side of the laptop next to the audio ports.
  • This will release the speaker grille.
Agregar Comentario
Flip the computer back over and open the screen.
  • Flip the computer back over and open the screen.
Agregar Comentario
Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward.  The grille will still be connected by a white electrical strip. Carefully pull out the white electrical strip. Carefully pull out the white electrical strip.
  • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
  • Carefully pull out the white electrical strip.
Agregar Comentario
Remove the 4mm Phillips screw in the center (located to the left of the green strip). Carefully pull the green strip straight up to disconnect it. The keyboard can now be removed.
  • Remove the 4mm Phillips screw in the center (located to the left of the green strip).
  • Carefully pull the green strip straight up to disconnect it.
  • The keyboard can now be removed.
Agregar Comentario
Conclusión
Sara Lillard
Miembro Desde 11/04/11
93 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 12-36, Maness Spring 2011 Miembro de Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 1,548
