Saltar al contenido principal
Sony VAIO PCG-933A Floppy Disk Drive Replacement
  1. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: paso 1, imagen 1 de 2 Sony VAIO PCG-933A Floppy Disk Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Floppy Disk Drive Replacement: paso 2, imagen 1 de 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: paso 2, imagen 2 de 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: paso 2, imagen 3 de 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Floppy Disk Drive Replacement, Floppy Disk Drive: paso 3, imagen 1 de 1
    • With the laptop facing you, turn the laptop upside down.
  4. Sony VAIO PCG-933A Floppy Disk Drive Replacement: paso 4, imagen 1 de 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: paso 4, imagen 2 de 3 Sony VAIO PCG-933A Floppy Disk Drive Replacement: paso 4, imagen 3 de 3
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  5. Sony VAIO PCG-933A Floppy Disk Drive Replacement: paso 5, imagen 1 de 1
    • To replace, insert the new floppy disk drive with the wording facing down.
Conclusión
Sara Lillard
Miembro Desde 04/11/11
165 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 12-36, Maness Spring 2011 Miembro de Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 1,994
