Saltar al contenido principal
Sony PlayStation 3D Display Side Speakers Replacement
Qué necesitas
  1. Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: paso 1, imagen 1 de 2 Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Side Speakers Replacement: paso 2, imagen 1 de 3 Sony PlayStation 3D Display Side Speakers Replacement: paso 2, imagen 2 de 3 Sony PlayStation 3D Display Side Speakers Replacement: paso 2, imagen 3 de 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Side Speakers Replacement: paso 3, imagen 1 de 2 Sony PlayStation 3D Display Side Speakers Replacement: paso 3, imagen 2 de 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Side Speakers Replacement: paso 4, imagen 1 de 3 Sony PlayStation 3D Display Side Speakers Replacement: paso 4, imagen 2 de 3 Sony PlayStation 3D Display Side Speakers Replacement: paso 4, imagen 3 de 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: paso 5, imagen 1 de 3 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: paso 5, imagen 2 de 3 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: paso 5, imagen 3 de 3
    • With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
  6. Sony PlayStation 3D Display Side Speakers Replacement: paso 6, imagen 1 de 3 Sony PlayStation 3D Display Side Speakers Replacement: paso 6, imagen 2 de 3 Sony PlayStation 3D Display Side Speakers Replacement: paso 6, imagen 3 de 3
    • Remove the plastic plate covering the speaker.
    • When reassembling, make sure the arrow on the plastic plate is facing up.
    • Lift the speaker out of its holding tray.
  7. Sony PlayStation 3D Display Side Speakers Replacement: paso 7, imagen 1 de 2 Sony PlayStation 3D Display Side Speakers Replacement: paso 7, imagen 2 de 2
    • Remove the speaker by depressing the white tab on the speaker wire connector.
Conclusión
3 personas más completaron esta guía.
viharim
Miembro Desde 10/22/15
200 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 12-16, Maness Fall 2015 Miembro de Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Miembros
8 Guías creadas
Un comentario
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
Ferserk - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 29
Todo El Tiempo: 2,544
