Saltar al contenido principal
Sony M-430 Microcassette-Corder Speaker Replacement
Qué necesitas
  1. Sony M-430 Microcassette-Corder Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Speaker Replacement: paso 2, imagen 1 de 2 Sony M-430 Microcassette-Corder Speaker Replacement: paso 2, imagen 2 de 2
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: paso 3, imagen 1 de 2 Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: paso 3, imagen 2 de 2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Speaker Replacement: paso 4, imagen 1 de 2 Sony M-430 Microcassette-Corder Speaker Replacement: paso 4, imagen 2 de 2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Speaker Replacement: paso 5, imagen 1 de 1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Speaker Replacement: paso 6, imagen 1 de 1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  7. Sony M-430 Microcassette-Corder Speaker Replacement, Speaker: paso 7, imagen 1 de 1
    • The speaker is the large gold circular piece attached under where the batteries would normally be.
    • It is connected to the device with two black wires that run along one side of the motherboard, as shown on the top of the picture.
  8. Sony M-430 Microcassette-Corder Speaker Replacement: paso 8, imagen 1 de 2 Sony M-430 Microcassette-Corder Speaker Replacement: paso 8, imagen 2 de 2
    • Depending on the replacement speaker you have, there are two places you can desolder the wire.
    • If your replacement speaker has a wire already attached to it, desolder the old wire from where it connects to the motherboard.
    • If the replacement speaker has no wire, desolder the old wire where it connects to the broken speaker.
  9. Sony M-430 Microcassette-Corder Speaker Replacement: paso 9, imagen 1 de 2 Sony M-430 Microcassette-Corder Speaker Replacement: paso 9, imagen 2 de 2
    • Unscrew the 2 Phillips head screws (2x2.5 mm) around the edge of the speaker with a #00 Phillips screwdriver.
    • Use a pair of tweezers to remove the black tape on the speaker. Put the tape on the back of the new speaker.
  10. Sony M-430 Microcassette-Corder Speaker Replacement: paso 10, imagen 1 de 1
    • Now that the speaker is detached from the device, simply tilt the device over and let the speaker fall out.
Conclusión
Matt Teare
Miembro Desde 01/20/12
35 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-34, Amido Winter 2012 Miembro de Cal Poly, Team 10-34, Amido Winter 2012
CPSU-AMIDO-W12S10G34
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 871
