Introducción
This guide will show you how to remove the Dark Grey case that allows you access to the Motherboard.
Partes
No se requieren partes.
To remove the back cover, use your thumb to press down on the center of case and slide it off.
  • To remove the back cover, use your thumb to press down on the center of case and slide it off.
Agregar Comentario
Using a fingernail lift the battery out of the phone.
  • Using a fingernail lift the battery out of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Slide the sim card out with your thumb.
  • Slide the sim card out with your thumb.
Agregar Comentario
To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
Agregar Comentario
Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
Agregar Comentario
Lift up towards the bottom and slide the case off.
  • Lift up towards the bottom and slide the case off.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Alex Serventi
Miembro Desde 07/10/10
50 Reputación
26 Guías creadas
Equipo
Cal Poly, Team 5-15, Maness Fall 2010 Miembro de Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Miembros
26 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 980
