Introducción
This can be time consuming if this is your first time taking apart the phone. The replacement of the motherboard is very straight forward; however, if a full replacement is necessary it may be more cost effective to replace the phone. Use this guide if you are having hardware issues and find it appropriate to replace the phone's chipset.
Partes
No se requieren partes.
Remove the back cover by sliding it off.
  • Remove the back cover by sliding it off.
Agregar Comentario
Once the back cover is removed, pull out the battery using your finger as shown.
  • Once the back cover is removed, pull out the battery using your finger as shown.
Agregar Comentario
The battery can now be replaced if desired.
  • The battery can now be replaced if desired.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Locate the four 6mm screws on the back of the phone.
  • Locate the four 6mm screws on the back of the phone.
  • Using a small Phillips head screwdriver, remove the four screws.
Agregar Comentario
Flip the phone over and slide it open. Using the prying tool, remove the plastic piece covering the microphone.
  • Flip the phone over and slide it open.
  • Using the prying tool, remove the plastic piece covering the microphone.
  • Locate and remove the two 6mm screws located under the plastic piece and remove them using a small Phillips screwdriver.
Agregar Comentario
Use the plastic opening tool to remove the black plastic cover from the rest of the phone. It is best to start from the bottom of the phone by the memory card slot. The cover should pop out of place by the four corners of the phone. There is no need to use excessive force as this may cause the plastic to break.
  • Use the plastic opening tool to remove the black plastic cover from the rest of the phone.
  • It is best to start from the bottom of the phone by the memory card slot.
  • The cover should pop out of place by the four corners of the phone. There is no need to use excessive force as this may cause the plastic to break.
Agregar Comentario
Once the back cover is removed, remove the small black piece shown in the picture.
  • Once the back cover is removed, remove the small black piece shown in the picture.
Agregar Comentario
Using the plastic opening tool, slide around the motherboard to loosen it.
  • Using the plastic opening tool, slide around the motherboard to loosen it.
  • Lift the motherboard up but not completely because in order to remove the motherboard you need to lift and pull it out.
Agregar Comentario
Using the plastic opening tool, separate the connectors to the screen. Make sure to note the orientation and location of each cable before disconnecting. This will ensure that the motherboard will be reconnected properly.
  • Using the plastic opening tool, separate the connectors to the screen.
  • Make sure to note the orientation and location of each cable before disconnecting. This will ensure that the motherboard will be reconnected properly.
  • Once the old motherboard is removed insert the new one if desired, and then reassemble the phone.
Agregar Comentario
Conclusión
Mike
Miembro Desde 21/11/11
31 Reputación
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,265
