Introducción
This guide will show you how to access and replace the main keypad of the phone. Use this guide if the keypad needs to be cleaned or repaired. You can also remove the keypad, decorate it, and have your phone stand apart from the crowd.
Partes
No se requieren partes.
Remove the back cover by sliding it off.
  • Remove the back cover by sliding it off.
Agregar Comentario
Once the back cover is removed, pull out the battery using your finger as shown.
  • Once the back cover is removed, pull out the battery using your finger as shown.
Agregar Comentario
The battery can now be replaced if desired.
  • The battery can now be replaced if desired.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the four marked screws in the photograph with the screw driver.
  • Remove the four marked screws in the photograph with the screw driver.
Agregar Comentario
Remove plastic cover with a plastic opening tool.
  • Remove plastic cover with a plastic opening tool.
  • It is easiest to begin at the SD card slot and alternate prying the cover on opposite sides.
  • The cover will not come off all the way, but will only pry loose up to the camera. This is because there are additional screws that need to be removed.
Agregar Comentario
Using a plastic opening tool, pry off the plastic piece at the bottom of the keypad.
  • Using a plastic opening tool, pry off the plastic piece at the bottom of the keypad.
  • Note: This piece is fixed with an adhesive, so you must break the bond in order to reach the screws underneath. It may be necessary to use additional adhesive during reassembly.
Agregar Comentario
Unscrew both 6mm screws beneath the previously removed plastic cover using a phillips head screw driver
  • Unscrew both 6mm screws beneath the previously removed plastic cover using a phillips head screw driver
  • After removing these screws, you can completely remove the back plastic cover.
Agregar Comentario
Begin prying the board from the plastic case using a plastic opening tool. This part is tricky. The black plastic pieces at the base of the phone (marked) hold the board in.
  • Begin prying the board from the plastic case using a plastic opening tool.
  • This part is tricky. The black plastic pieces at the base of the phone (marked) hold the board in.
Agregar Comentario
After removing the board, you will see the plastic keyboard beneath. This can be easily removed by hand and is very flexible.
  • After removing the board, you will see the plastic keyboard beneath. This can be easily removed by hand and is very flexible.
  • You have now successfully removed the keypad. You can now clean, decorate, or replace it without worrying about damaging the phone.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,195
