Partes
No se requieren partes.
Lie phone screen down on a flat smooth surface so that the camera, logos, and speaker face up. Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  • Lie phone screen down on a flat smooth surface so that the camera, logos, and speaker face up.
  • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Lie the cover beside the phone upon removal.  Your assembly should appear as shown this far. Insert the plastic opening tool into the crevice between the camera and the battery of the phone.  Using a gentle prying motion, lift the end of the battery and remove. After removal, recycle the defective battery appropriately.  Take the replacement battery and lie it near the phone as shown.  Your assembly should resemble the presented picture.  Note that the cover is not included in this particular photo.
  • Lie the cover beside the phone upon removal. Your assembly should appear as shown this far.
  • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
  • After removal, recycle the defective battery appropriately. Take the replacement battery and lie it near the phone as shown. Your assembly should resemble the presented picture. Note that the cover is not included in this particular photo.
Agregar Comentario
Slide the SIM card into the lower right slot identified by the circle in the picture, ensuring the contacts are aligned properly.
  • Slide the SIM card into the lower right slot identified by the circle in the picture, ensuring the contacts are aligned properly.
Agregar Comentario
Conclusión
Parker Stroble
Miembro Desde 09/03/12
74 Reputación
6 Guías creadas
Equipo
Clemson, Team 1-4, Benson Spring 2012 Miembro de Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 791
