Saltar al contenido principal
Sony Ericsson W350a Memory Card Replacement
Qué necesitas
  1. Sony Ericsson W350a Memory Card Replacement, Battery: paso 1, imagen 1 de 2 Sony Ericsson W350a Memory Card Replacement, Battery: paso 1, imagen 2 de 2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Sony Ericsson W350a Memory Card Replacement: paso 2, imagen 1 de 3 Sony Ericsson W350a Memory Card Replacement: paso 2, imagen 2 de 3 Sony Ericsson W350a Memory Card Replacement: paso 2, imagen 3 de 3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  3. Sony Ericsson W350a Memory Card Replacement, Memory Card: paso 3, imagen 1 de 1
    • After removing the battery, insert the memory card into the lower left slot as designated by the circle in the picture. Be sure to have the contacts aligned into their appropriate slots.
Conclusión
Parker Stroble
Miembro Desde 03/09/12
86 Reputación
3 Guías creadas
Equipo
Clemson, Team 1-4, Benson Spring 2012 Miembro de Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 1,197
