Introducción
Replacing a faulty LCD is relatively simple, just be patient and gentle while replacing the screen.
Slide the battery cover up and off the phone. Slide the battery cover up and off the phone.
  • Slide the battery cover up and off the phone.
Agregar Comentario
Pop the battery out of its slot by lifting it up. Pop the battery out of its slot by lifting it up.
  • Pop the battery out of its slot by lifting it up.
Agregar Comentario
Insert the plastic opening tool in between the front case and the back case. Apply downward pressure to make the case lift upwards, thus popping the front case off. Use caution when removing the front case. It may seem stuck but just ease it out.
  • Insert the plastic opening tool in between the front case and the back case.
  • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
Agregar Comentario
Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver. Note that the top 2 screws are silver and the bottom 2 screws are black.
  • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
Agregar Comentario
There is a black tab in the top left corner holding the core in place. Remove the core by pulling straight up to prevent breaking the tab. Remove the core by pulling straight up to prevent breaking the tab.
  • There is a black tab in the top left corner holding the core in place.
  • Remove the core by pulling straight up to prevent breaking the tab.
Agregar Comentario
Undo the metal clip on each side of the core using the plastic opening tool. Do not bend clips past 2mm or they could break. Do not bend clips past 2mm or they could break.
  • Undo the metal clip on each side of the core using the plastic opening tool.
    • Do not bend clips past 2mm or they could break.
Agregar Comentario
Gently pull the white keyboard and charging port away from the motherboard and off the phone. Gently pull the white keyboard and charging port away from the motherboard and off the phone. Gently pull the white keyboard and charging port away from the motherboard and off the phone.
  • Gently pull the white keyboard and charging port away from the motherboard and off the phone.
Agregar Comentario
Undo the grey clip that holds the LCD ribbon in place by loosening one side of the clip with the plastic opening tool, then gently separate the other side of the clip from the holder. The copper end of the ribbon should slide out of the housing as you pull the LCD up and away from the motherboard. Using too much force may bend the copper ribbon.
  • Undo the grey clip that holds the LCD ribbon in place by loosening one side of the clip with the plastic opening tool, then gently separate the other side of the clip from the holder.
  • The copper end of the ribbon should slide out of the housing as you pull the LCD up and away from the motherboard.
    • Using too much force may bend the copper ribbon.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Austin Cade
Miembro Desde 11/01/11
184 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-10, Forte Winter 2011 Miembro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 7
Todo El Tiempo: 7,454
