Introducción
Removing the front case is easy, just be careful when you take it off.
Partes
No se requieren partes.
Insert the plastic opening tool in between the front case and the back case. Apply downward pressure to make the case lift upwards, thus popping the front case off. Use caution when removing the front case. It may seem stuck but just ease it out.
  • Insert the plastic opening tool in between the front case and the back case.
  • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Conclusión
To reassemble your device, follow these instructions in reverse.
Una persona más ha completado esta guía.
Emily Prescott
Miembro Desde 10/01/11
461 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 14-10, Forte Winter 2011 Miembro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,676
