Saltar al contenido principal
Sony Ericsson W200i Back Case Replacement
Qué necesitas
  1. Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: paso 1, imagen 1 de 2 Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: paso 1, imagen 2 de 2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Back Case Replacement: paso 2, imagen 1 de 2 Sony Ericsson W200i Back Case Replacement: paso 2, imagen 2 de 2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Back Case Replacement, Front Case: paso 3, imagen 1 de 3 Sony Ericsson W200i Back Case Replacement, Front Case: paso 3, imagen 2 de 3 Sony Ericsson W200i Back Case Replacement, Front Case: paso 3, imagen 3 de 3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Back Case Replacement, Core: paso 4, imagen 1 de 2 Sony Ericsson W200i Back Case Replacement, Core: paso 4, imagen 2 de 2
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i Back Case Replacement: paso 5, imagen 1 de 3 Sony Ericsson W200i Back Case Replacement: paso 5, imagen 2 de 3 Sony Ericsson W200i Back Case Replacement: paso 5, imagen 3 de 3
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i Back Case Replacement, Back Case: paso 6, imagen 1 de 3 Sony Ericsson W200i Back Case Replacement, Back Case: paso 6, imagen 2 de 3 Sony Ericsson W200i Back Case Replacement, Back Case: paso 6, imagen 3 de 3
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
Conclusión
To reassemble your device, put removed pieces into the new back casing, then follow the steps in reverse order.
Emily Prescott
Miembro Desde 01/10/11
531 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 14-10, Forte Winter 2011 Miembro de Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 3,651
