Saltar al contenido principal
Sony Ericsson TM506 Motherboard Replacement
Qué necesitas
  1. Sony Ericsson TM506 Motherboard Replacement, Battery Cover: paso 1, imagen 1 de 3 Sony Ericsson TM506 Motherboard Replacement, Battery Cover: paso 1, imagen 2 de 3 Sony Ericsson TM506 Motherboard Replacement, Battery Cover: paso 1, imagen 3 de 3
    • Firmly hold the phone between your fingers with your thumb on the battery cover.
    • Push down with your thumb until the battery cover comes off.
  2. Sony Ericsson TM506 Motherboard Replacement, Back Case: paso 2, imagen 1 de 3 Sony Ericsson TM506 Motherboard Replacement, Back Case: paso 2, imagen 2 de 3 Sony Ericsson TM506 Motherboard Replacement, Back Case: paso 2, imagen 3 de 3
    • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
  3. Sony Ericsson TM506 Motherboard Replacement: paso 3, imagen 1 de 2 Sony Ericsson TM506 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the two rubber casings for the top two screws with a plastic opening tool.
  4. Sony Ericsson TM506 Motherboard Replacement: paso 4, imagen 1 de 1
    • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson TM506 Motherboard Replacement: paso 5, imagen 1 de 3 Sony Ericsson TM506 Motherboard Replacement: paso 5, imagen 2 de 3 Sony Ericsson TM506 Motherboard Replacement: paso 5, imagen 3 de 3
    • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
  6. Sony Ericsson TM506 Motherboard Replacement, Sound Box: paso 6, imagen 1 de 3 Sony Ericsson TM506 Motherboard Replacement, Sound Box: paso 6, imagen 2 de 3 Sony Ericsson TM506 Motherboard Replacement, Sound Box: paso 6, imagen 3 de 3
    • The sound box is attached to the case by two snap hooks.
    • Lift the sound box up to remove it from the case.
  7. Sony Ericsson TM506 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 Sony Ericsson TM506 Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Locate the 80-pin connector.
    • Carefully, lift up on the connector to separate it from the board.
  8. Sony Ericsson TM506 Motherboard Replacement: paso 8, imagen 1 de 3 Sony Ericsson TM506 Motherboard Replacement: paso 8, imagen 2 de 3 Sony Ericsson TM506 Motherboard Replacement: paso 8, imagen 3 de 3
    • There are two snap hooks that attach the motherboard to the case.
    • Using a plastic opening tool, carefully lift up on the motherboard to detach it.
    • The motherboard is extremely fragile. Try to be forceful yet delicate in the removal because it will not come off easily.
Conclusión
Daniel
Miembro Desde 06/20/12
83 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 1-1, Regan SU 2012 Miembro de Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 1,150
