Introducción
This guide provides instruction for installing a back case for the Sony Ericsson TM506 cell phone.
Partes
No se requieren partes.
Firmly hold the phone between your fingers with your thumb on the battery cover. Push down with your thumb until the battery cover comes off. Push down with your thumb until the battery cover comes off.
  • Firmly hold the phone between your fingers with your thumb on the battery cover.
  • Push down with your thumb until the battery cover comes off.
Agregar Comentario
Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver. Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver. Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
  • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
Agregar Comentario
Remove the two rubber casings for the top two screws with a plastic opening tool. Remove the two rubber casings for the top two screws with a plastic opening tool.
  • Remove the two rubber casings for the top two screws with a plastic opening tool.
Agregar Comentario
Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
  • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
Agregar Comentario
There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case. There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case. There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
  • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Minnal
Miembro Desde 09/07/12
16 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 1-1, Regan SU 2012 Miembro de Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 434
