Introducción
This guide will assist you in removing the speaker from your Sony Ericsson T68i.
Partes
No se requieren partes.
Remove the battery from the back. Remove the battery from the back.
  • Remove the battery from the back.
Agregar Comentario
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
  • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
  • Do not bend it too far down, or else you risk breaking the two bottom clips.
Agregar Comentario
Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
  • Unscrew all four Torx T6 screws.
  • Keep in a safe place.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
  • After removing the screws, the two halves will separate. If not, then pry them gently apart.
Agregar Comentario
Remove the circuit board and screen from the device. Use your T6 to remove the 4 screws. Use your T6 to remove the 4 screws.
  • Remove the circuit board and screen from the device.
  • Use your T6 to remove the 4 screws.
Agregar Comentario
Remove the board and screen. Remove the board and screen. Remove the board and screen.
  • Remove the board and screen.
Agregar Comentario
Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board.
  • Carefully remove the plastic clips holding the screen on the board.
Agregar Comentario
Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool. Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool. Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool.
  • Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool.
Agregar Comentario
Conclusión
Tim Dascomb
Miembro Desde 13/04/10
123 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 26-34, Regan Spring 2010 Miembro de Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Miembros
13 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,096
