Introducción
This guide will show the user how to disassemble a Sony Ericsson J22Oi with the intent of removing and replacing the charging port.
Partes
No se requieren partes.
Before disassembling the phone, make sure the phone is powered off.
  • Before disassembling the phone, make sure the phone is powered off.
Agregar Comentario
Flip to the back of the phone and locate the black button on the top of the phone.
  • Flip to the back of the phone and locate the black button on the top of the phone.
Agregar Comentario
Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
Agregar Comentario
Remove the battery by wedging it out from the back.
  • Remove the battery by wedging it out from the back.
Agregar Comentario
Flip to the front of the phone and apply pressure to the front frame of the phone.  The frame should snap off easily.
  • Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the keypad by gently pulling it from the front of the phone.
  • Remove the keypad by gently pulling it from the front of the phone.
Agregar Comentario
Locate the five screws indicated on the phone.
  • Locate the five screws indicated on the phone.
Agregar Comentario
Use a T5 Screwdriver and unscrew the five screws.
  • Use a T5 Screwdriver and unscrew the five screws.
Agregar Comentario
Once the screws are off, there should be a plastic cover on top of your screen.  Gently slide the plastic cover off.
  • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
Agregar Comentario
Now gently pull metal cover off.
  • Now gently pull metal cover off.
Agregar Comentario
You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone.  Apply some force to pop out the screen.
  • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
Agregar Comentario
Now that screen is removed, replace the old screen with the new screen.
  • Now that screen is removed, replace the old screen with the new screen.
  • Reassemble the device by doing the steps in reverse order.
Agregar Comentario
After removing the screen, you will find the charging port located at the bottom of the phone.
  • After removing the screen, you will find the charging port located at the bottom of the phone.
Agregar Comentario
Gently slide off the charging port.
  • Gently slide off the charging port.
Agregar Comentario
Conclusión
James Au
Miembro Desde 06/10/12
10 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-36, Regan Fall 2012 Miembro de Cal Poly, Team 6-36, Regan Fall 2012
CPSU-REGAN-F12S6G36
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,038
