Saltar al contenido principal
Sony DVP-SR200P Button Circuit Board Replacement
Qué necesitas
  1. Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: paso 1, imagen 1 de 2 Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: paso 1, imagen 2 de 2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P Button Circuit Board Replacement: paso 2, imagen 1 de 2 Sony DVP-SR200P Button Circuit Board Replacement: paso 2, imagen 2 de 2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P Button Circuit Board Replacement, Processing Board: paso 3, imagen 1 de 1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P Button Circuit Board Replacement: paso 4, imagen 1 de 2 Sony DVP-SR200P Button Circuit Board Replacement: paso 4, imagen 2 de 2
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P Button Circuit Board Replacement: paso 5, imagen 1 de 1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P Button Circuit Board Replacement: paso 6, imagen 1 de 1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P Button Circuit Board Replacement, DVD Drive: paso 7, imagen 1 de 1
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
  8. Sony DVP-SR200P Button Circuit Board Replacement: paso 8, imagen 1 de 1
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
  9. Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: paso 9, imagen 1 de 3 Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: paso 9, imagen 2 de 3 Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: paso 9, imagen 3 de 3
    • Orient the DVD player so the button circuit board is facing you.
    • Remove the four #1 Phillips screws (silver, 3/16") from the button circuit board.
    • Three 3/16" screws from the longer button circuit board.
    • One 3/16" screw from the smaller button circuit board.
  10. Sony DVP-SR200P Button Circuit Board Replacement: paso 10, imagen 1 de 3 Sony DVP-SR200P Button Circuit Board Replacement: paso 10, imagen 2 de 3 Sony DVP-SR200P Button Circuit Board Replacement: paso 10, imagen 3 de 3
    • Hold down the copper brace that is near the far right screw hole of the long circuit board.
    • Lift the longer button circuit board over the copper brace and out of its position.
  11. Sony DVP-SR200P Button Circuit Board Replacement: paso 11, imagen 1 de 3 Sony DVP-SR200P Button Circuit Board Replacement: paso 11, imagen 2 de 3 Sony DVP-SR200P Button Circuit Board Replacement: paso 11, imagen 3 de 3
    • Push back the black, plastic clip near the left center of the shorter button circuit board.
    • Pull the shorter button circuit board out of its position.
  12. Sony DVP-SR200P Button Circuit Board Replacement: paso 12, imagen 1 de 2 Sony DVP-SR200P Button Circuit Board Replacement: paso 12, imagen 2 de 2
    • Wiggle the white cord connecting the two boards out from under the plastic pieces securing the cord.
    • Lift the button circuit board out of the DVD player.
Conclusión
2 personas más completaron esta guía.
Jeffrey Powell
Miembro Desde 01/11/13
157 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 5-17, Forte Winter 2013 Miembro de Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 2,323
