Introducción
If the monitor or screen is broken, the monitor needs to be detached from the device.
Remove the five exposed 7.9 mm phillips screws with the spudger.
  • Remove the five exposed 7.9 mm phillips screws with the spudger.
  • Punch through the warranty sticker with the spudger and remove the screw underneath.
Agregar Comentario
Remove the rubber feet with the screwdriver.
  • Remove the rubber feet with the screwdriver.
  • Remove the screws that the rubber feet were covering.
Agregar Comentario
Lift up the cover gently.
  • Lift up the cover gently.
  • The tray is still connected to the base with wires.
Agregar Comentario
Remove the wires with tweezers by gently pulling on the base they are attached to.
  • Remove the wires with tweezers by gently pulling on the base they are attached to.
Agregar Comentario
Use your hand to remove the small back cover. Use your hand to remove the small back cover.
  • Use your hand to remove the small back cover.
Agregar Comentario
Remove the two 0.473" pan head screws as shown circled in the picture
  • Remove the two 0.473" pan head screws as shown circled in the picture
Agregar Comentario
The screen should now detach from the main device.
  • The screen should now detach from the main device.
  • The screen will still be connected by the wires
Agregar Comentario
Remove the wires attached to the white base by using the tweezers Remove the wires attached to the white base by using the tweezers
  • Remove the wires attached to the white base by using the tweezers
Agregar Comentario
Do the same with the wires attached to the black base. Do the same with the wires attached to the black base.
  • Do the same with the wires attached to the black base.
Agregar Comentario
The screen should now be completely separated from the main device.
  • The screen should now be completely separated from the main device.
Agregar Comentario
Conclusión
Andrew Ward
Miembro Desde 20/01/12
39 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-21, Maness Winter 2012 Miembro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 14
Todo El Tiempo: 2,516
