Saltar al contenido principal
Sony DVP-FX730 Laser Replacement
Qué necesitas
  1. Sony DVP-FX730 Laser Replacement, Cover: paso 1, imagen 1 de 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Laser Replacement: paso 2, imagen 1 de 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Laser Replacement: paso 3, imagen 1 de 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Laser Replacement: paso 4, imagen 1 de 1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Laser Replacement, Laser: paso 5, imagen 1 de 2 Sony DVP-FX730 Laser Replacement, Laser: paso 5, imagen 2 de 2
    • Remove the large connector.
    • Remove the small connector.
  6. Sony DVP-FX730 Laser Replacement: paso 6, imagen 1 de 1
    • Remove Philips screws with the #0 Philips Screwdriver.
  7. Sony DVP-FX730 Laser Replacement: paso 7, imagen 1 de 1
    • Lift up the black piece connected to the wires.
    • Lift gently because the ribbon cable is attached to the bottom.
  8. Sony DVP-FX730 Laser Replacement: paso 8, imagen 1 de 2 Sony DVP-FX730 Laser Replacement: paso 8, imagen 2 de 2
    • Unlock the lock clip
  9. Sony DVP-FX730 Laser Replacement: paso 9, imagen 1 de 1
    • Remove the T6 screws with the T6 screwdriver.
  10. Sony DVP-FX730 Laser Replacement: paso 10, imagen 1 de 1
    • Gently pull the rods out with tweezers.
    • Be sure the laser is out of the way so that the rods can be removed.
  11. Sony DVP-FX730 Laser Replacement: paso 11, imagen 1 de 2 Sony DVP-FX730 Laser Replacement: paso 11, imagen 2 de 2
    • Pull laser off of the rods.
    • Be careful when removing the rods because a fragile metal piece may break.
  12. Sony DVP-FX730 Laser Replacement: paso 12, imagen 1 de 1
    • The laser is now removed.
Conclusión
Equipo
Cal Poly, Team 11-21, Maness Winter 2012 Miembro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Miembros
5 Guías creadas
Un comentario
where do I buy the lens?
mnmmacd - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 4,701
