Introducción
We will explain the steps needed in order to replace a LCD screen.
Slide the battery cover in the direction the arrow points. Pull the battery cover towards you.
  • Slide the battery cover in the direction the arrow points.
  • Pull the battery cover towards you.
Agregar Comentario
Flick the blue switch for the battery to pop out. Remove the battery from the camera.
  • Flick the blue switch for the battery to pop out.
  • Remove the battery from the camera.
Agregar Comentario
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel. Remove that panel.
  • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
  • Remove that panel.
  • Careful for falling pieces.
Agregar Comentario
Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel). Remove that panel.
  • Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
Agregar Comentario
Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
  • Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
Agregar Comentario
Gently remove the back cover. It may be a bit stiff, so use some force to remove it. Proceed with caution.
  • Gently remove the back cover.
  • It may be a bit stiff, so use some force to remove it. Proceed with caution.
Agregar Comentario
Remove the screw using a Phillips #00 Screwdriver on the left side (where the "3x optical zoom" panel use to be).
  • Remove the screw using a Phillips #00 Screwdriver on the left side (where the "3x optical zoom" panel use to be).
Agregar Comentario
Remove the small screw using a Phillips #00 Screwdriver on the bottom of the camera attached to the front cover. Gently remove the front cover. Put a little force to pop off the case. Proceed with caution.
  • Remove the small screw using a Phillips #00 Screwdriver on the bottom of the camera attached to the front cover.
  • Gently remove the front cover.
  • Put a little force to pop off the case. Proceed with caution.
Agregar Comentario
Flip the black secure locks off. Tweezers may be necessary. Detach the two  orange cables.
  • Flip the black secure locks off. Tweezers may be necessary.
  • Detach the two orange cables.
Agregar Comentario
Gently pull the lens container out of the camera. Gently pull the lens container out of the camera.
  • Gently pull the lens container out of the camera.
Agregar Comentario
Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
Agregar Comentario
Remove the two orange cables on the top of the motherboard with tweezers. Lift the motherboard out of its slot.
  • Remove the two orange cables on the top of the motherboard with tweezers.
  • Lift the motherboard out of its slot.
Agregar Comentario
For the AV port, detach the bottom orange cable. For the LCD screen, detach the top orange cable on the right side of the motherboard.
  • For the AV port, detach the bottom orange cable.
  • For the LCD screen, detach the top orange cable on the right side of the motherboard.
  • For the motherboard, detach all the orange cables.
  • Careful not to damage the red, white, and black wires when lifting the board.
Agregar Comentario
Verify the orange cables from the motherboard are removed from the LCD screen. Lift the LCD screen off the hinge. Lift the LCD screen off the hinge.
  • Verify the orange cables from the motherboard are removed from the LCD screen.
  • Lift the LCD screen off the hinge.
Agregar Comentario
Verify that the LCD screen is attached to the chip on the back on the camera. Remove the dial from the back of the camera. It pops right off very easily. Remove the screw using a Phillips #00 Screwdriver from the camera.
  • Verify that the LCD screen is attached to the chip on the back on the camera.
  • Remove the dial from the back of the camera. It pops right off very easily.
  • Remove the screw using a Phillips #00 Screwdriver from the camera.
Agregar Comentario
Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force. Remove the chip and the LCD screen now from the camera.
  • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
  • Remove the chip and the LCD screen now from the camera.
  • The chip may need a slight upward tug with a fingernail or tweezer.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Eddie Lo
Miembro Desde 11/10/10
218 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-20, Regan Fall 2010 Miembro de Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 8
Últimos 30 Días: 24
Todo El Tiempo: 12,777
