Saltar al contenido principal
Sony Cyber-shot DSC-W5 battery compartment replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W5 battery compartment replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 2, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 2, imagen 2 de 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 3, imagen 2 de 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 battery compartment replacement, LCD Screen: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement, LCD Screen: paso 4, imagen 2 de 2
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 5, imagen 1 de 1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 6, imagen 2 de 2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 7, imagen 1 de 3 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 7, imagen 2 de 3 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 7, imagen 3 de 3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
  8. Sony Cyber-shot DSC-W5 battery compartment replacement, Speaker: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement, Speaker: paso 8, imagen 2 de 2
    • Remove the two screws holding down the steel back plate.
    • Remove steel back plate.
  9. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 9, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 9, imagen 2 de 2
    • Now remove the plastic plate that covers the motherboard.
  10. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 10, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 10, imagen 2 de 2
    • Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors store electric charge even if the batteries are removed.
    • Remove the blue cable.
  11. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 11, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 11, imagen 2 de 2
    • Disconnect the flash cable (black and white wires) before completely removing the front case.
    • Gently start to remove the case.
    • Once the cable is free, set aside the front case.
  12. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 12, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement: paso 12, imagen 2 de 2
    • The speaker should now be clearly seen on the underside of the camera.
    • Gently unplug the speaker from the motherboard.
    • Replace the speaker.
  13. Sony Cyber-shot DSC-W5 battery compartment replacement, Battery Terminal: paso 13, imagen 1 de 2 Sony Cyber-shot DSC-W5 battery compartment replacement, Battery Terminal: paso 13, imagen 2 de 2
    • Remove the orange cable connecting the battery terminal to the motherboard.
  14. Sony Cyber-shot DSC-W5 battery compartment replacement: paso 14, imagen 1 de 1
    • The battery terminal is now free from the board and can be slid out.
Conclusión
5 personas más completaron esta guía.
Thomas
Miembro Desde 04/14/10
133 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 15-50, Garner Spring 2010 Miembro de Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Miembros
12 Guías creadas
Un comentario
Clean the little nobs in the pattery-pack and problem solved! I also removed the black plastic ring that was on the +pole inside.
martinenjellie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 90
Todo El Tiempo: 16,191
