Saltar al contenido principal
Sony Cyber-shot DSC-W5 LCD Screen Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-W5 LCD Screen Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 2, imagen 1 de 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 3, imagen 1 de 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: paso 4, imagen 2 de 2
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 6, imagen 1 de 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 6, imagen 2 de 2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 7, imagen 1 de 3 Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 7, imagen 2 de 3 Sony Cyber-shot DSC-W5 LCD Screen Replacement: paso 7, imagen 3 de 3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
Conclusión
4 personas más completaron esta guía.
Thomas
Miembro Desde 04/14/10
133 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 15-50, Garner Spring 2010 Miembro de Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 11,358
