Introducción
Make sure you have all of the requisite tools on hand before beginning to replace the flash bulb and its casing.
Find the hatch labeled "open" on the left side of the bottom of the camera.
  • Find the hatch labeled "open" on the left side of the bottom of the camera.
  • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Agregar Comentario
Slide the blue locking tab to release the battery. Slide the battery out of the camera.
  • Slide the blue locking tab to release the battery. Slide the battery out of the camera.
Agregar Comentario
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera. Remove the four 2.5mm Philips #0 screws.
  • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
  • Remove the four 2.5mm Philips #0 screws.
Agregar Comentario
Turn the camera so the left side-panel faces you. (It says 5x Optical Zoom) Remove the two 2.5mm Philips #0 screws. You may have to remove the screws with a pair of tweezers when the screws are almost out.
  • Turn the camera so the left side-panel faces you. (It says 5x Optical Zoom)
  • Remove the two 2.5mm Philips #0 screws.
  • You may have to remove the screws with a pair of tweezers when the screws are almost out.
Agregar Comentario
Turn the camera so the right side faces you. Remove the two 2.5mm Philips #0 screws. You may have to remove the screws with a pair of tweezers when the screws are almost out.
  • Turn the camera so the right side faces you.
Agregar Comentario
Rotate camera so that the back is facing you.
  • Rotate camera so that the back is facing you.
  • Pull the back casing directly away from the LCD screen.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Turn the camera so that the left side is facing you. Pull the left side-panel off of the camera.
  • Turn the camera so that the left side is facing you.
  • Pull the left side-panel off of the camera.
Agregar Comentario
Turn camera so that the front of the camara is facing you. Pull the front casing directly away from the camera.
  • Turn camera so that the front of the camara is facing you.
  • Pull the front casing directly away from the camera.
  • The right side panel may fall off when you take the front panel off.
Agregar Comentario
Turn the camera so that the right side is facing you. Pull the right side-panel away from the rest of the camera.
  • Turn the camera so that the right side is facing you.
  • Pull the right side-panel away from the rest of the camera.
Agregar Comentario
This is what your camera should look like now that you have removed the casing from all sides. This is what your camera should look like now that you have removed the casing from all sides.
  • This is what your camera should look like now that you have removed the casing from all sides.
Agregar Comentario
Gently pull the LCD and its casing away from the motherboard as shown.
  • Gently pull the LCD and its casing away from the motherboard as shown.
  • Be careful not to rip out any ribbon cables.
Agregar Comentario
Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard. Do not use excessive force to remove the wire because this may cause it to tear.
  • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
  • Do not use excessive force to remove the wire because this may cause it to tear.
Caution: Do NOT attempt to remove the logic board itself until the LCD is completely off.
Sanat Sahasrabudhe - Contestar
Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard. Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
Agregar Comentario
Pull the LCD and its casing away from the rest of the camera.
  • Pull the LCD and its casing away from the rest of the camera.
Agregar Comentario
Turn the camera so the back is facing you. Remove the 2.5mm Philips #0 screw at the top of the camera.
  • Turn the camera so the back is facing you.
  • Remove the 2.5mm Philips #0 screw at the top of the camera.
Agregar Comentario
Tilt top casing up and towards you. Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top. Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
  • Tilt top casing up and towards you.
  • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
  • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
  • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Evan Mayer
Miembro Desde 05/10/10
318 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 7-54, Amido Fall 2010 Miembro de Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,146
