Saltar al contenido principal
Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Battery: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 3 de 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 4, imagen 2 de 2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, CCD Sensor Module: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, CCD Sensor Module: paso 5, imagen 2 de 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 6, imagen 1 de 1
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Flash Module: paso 7, imagen 1 de 3 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Flash Module: paso 7, imagen 2 de 3 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Flash Module: paso 7, imagen 3 de 3
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 8, imagen 2 de 2
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
  9. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Motherboard Assembly: paso 9, imagen 1 de 2 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement, Motherboard Assembly: paso 9, imagen 2 de 2
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  10. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 10, imagen 1 de 1
    • Remove the ribbon cables from these two ZIF connectors.
  11. Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 11, imagen 1 de 2 Sony Cyber-shot DSC-T1 Motherboard Assembly Replacement: paso 11, imagen 2 de 2
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
Conclusión
iDeleted
Miembro Desde 07/07/10
2,101 Reputación
39 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,113
