Saltar al contenido principal
Sony Cyber-shot DSC-T1 LCD screen Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-T1 LCD screen Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 2, imagen 1 de 1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: paso 3, imagen 3 de 3
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  4. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 4, imagen 1 de 1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 5, imagen 1 de 1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 6, imagen 1 de 1
    • After releasing the clips, pull out black lens box.
  7. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 7, imagen 1 de 2 Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 7, imagen 2 de 2
    • Use the plastic opening tool to flip the clip.
  8. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 8, imagen 1 de 2 Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 8, imagen 2 de 2
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
  9. Sony Cyber-shot DSC-T1 LCD screen Replacement, LCD screen: paso 9, imagen 1 de 1
    • Use the plastic opening tool to flip the top clip that holds the ribbon to the motherboard unit.
  10. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 10, imagen 1 de 2 Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 10, imagen 2 de 2
    • Flip the motherboard unit up to expose the metal plate beneath it.
    • Remove the four 3mm screws shown using the 00 screwdriver.
  11. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 11, imagen 1 de 1
    • Lift and remove the metal plate covering the LCD screen from the camera.
  12. Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 12, imagen 1 de 3 Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 12, imagen 2 de 3 Sony Cyber-shot DSC-T1 LCD screen Replacement: paso 12, imagen 3 de 3
    • Flip the LCD over to the other side of the camera.
    • Peel the tape connecting the LCD to the camera.
    • Remove LCD screen
Conclusión
Una persona más ha completado esta guía.
Paul Elrich
Miembro Desde 04/12/12
33 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-35, Maness Spring 2012 Miembro de Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 58
Todo El Tiempo: 3,261
