Introducción
Follow this guide for the process of replacing the CCD chip, which is responsible for converting light into digital images. For safety reasons, battery should be first removed.
Locate the cover on the bottom of the camera.
  • Locate the cover on the bottom of the camera.
  • Slide the cover towards the back of the camera.
  • Be careful—the battery can slide out on its own.
Agregar Comentario
Carefully remove the exposed battery.
  • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
Agregar Comentario
Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0  screwdriver. Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0  screwdriver. Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0  screwdriver.
  • Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0 screwdriver.
Agregar Comentario
Pull the two halves of the camera apart.
  • Pull the two halves of the camera apart.
  • Place the two halves down with the insides facing you.
Agregar Comentario
Find the two clips holding the motherboard to the black lens box.
  • Find the two clips holding the motherboard to the black lens box.
  • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it up. (If difficult, your fingernail can also be used)
Agregar Comentario
After releasing the clips, pull out the black lens box.
  • After releasing the clips, pull out the black lens box.
  • If the black lens box does not come out, go back to the previous step and make sure you released the correct clips.
Agregar Comentario
Locate and unscrew the two 3mm screws on the bottom of the black lens box with the JIS #0 screwdriver.
  • Locate and unscrew the two 3mm screws on the bottom of the black lens box with the JIS #0 screwdriver.
Agregar Comentario
With the tweezers remove the black tape to detach the chip from the lens box.
  • With the tweezers remove the black tape to detach the chip from the lens box.
Agregar Comentario
Grab the chip with your thumbs and carefully pull it off. The copper tab will be glued to the lens box. Be careful not to rip it.
  • Grab the chip with your thumbs and carefully pull it off.
  • The copper tab will be glued to the lens box. Be careful not to rip it.
    • The attached copper ribbons are part of the CCD chip.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Rosario
Miembro Desde 12/04/12
24 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-35, Maness Spring 2012 Miembro de Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 27
Todo El Tiempo: 2,873
