Saltar al contenido principal
Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement
Qué necesitas
  1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: paso 1, imagen 1 de 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: paso 2, imagen 1 de 1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 1 de 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 2 de 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: paso 3, imagen 3 de 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: paso 4, imagen 1 de 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: paso 4, imagen 2 de 2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: paso 5, imagen 1 de 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: paso 5, imagen 2 de 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: paso 6, imagen 1 de 1
    • Grasp the CCD Sensor Module and remove it.
Conclusión
2 personas más completaron esta guía.
iDeleted
Miembro Desde 07/07/10
2,101 Reputación
39 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 47
Todo El Tiempo: 12,943
