Partes
No se requieren partes.
Slide the battery latch down the side of the camera with your hands.
  • Slide the battery latch down the side of the camera with your hands.
  • The latch will automatically pop open.
Agregar Comentario
Unlatch the clip over the battery.
  • Unlatch the clip over the battery.
  • The battery will partially pop out.
Agregar Comentario
Remove the battery from the camera. Remove the battery from the camera.
  • Remove the battery from the camera.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver. Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
  • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
Agregar Comentario
Once the screws are removed, slowly remove the back casing from the rest of the camera. Once the screws are removed, slowly remove the back casing from the rest of the camera.
  • Once the screws are removed, slowly remove the back casing from the rest of the camera.
Agregar Comentario
Then, pull the front case away from the rest of the camera. Then, pull the front case away from the rest of the camera.
  • Then, pull the front case away from the rest of the camera.
Agregar Comentario
After the casing is removed, the camera should look as shown.
  • After the casing is removed, the camera should look as shown.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jenna Crawford
Miembro Desde 09/04/12
29 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 17-25, Amido Spring 2012 Miembro de Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 664
