Introducción
This guide is used for taking apart the case to fix many of the issues of the Sony Cybershot DSC-P52.
Partes
No se requieren partes.
Open the battery compartment and remove the batteries.
  • Open the battery compartment and remove the batteries.
  • Remove all of the visible screws on the outside of the case.
  • There should be three of them that are all easily located.
Agregar Comentario
Open the memory card compartment.
  • Open the memory card compartment.
  • Remove the screw next to the memory card slot.
Agregar Comentario
Pull apart the front and back cover pieces carefully.
  • Pull apart the front and back cover pieces carefully.
  • The front cover should come completely free with little effort.
  • The back cover will still be attached to the circuit board.
Agregar Comentario
Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
  • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
  • The circuitry will still be connected to the back case by ribbon cables.
Agregar Comentario
Open the case as shown.
  • Open the case as shown.
Agregar Comentario
Unclip the clip holding the ribbon cable in.
  • Unclip the clip holding the ribbon cable in.
  • Other ribbon cables might not have a clips.
Agregar Comentario
Pull the ribbon cable out.
  • Pull the ribbon cable out.
Agregar Comentario
Conclusión
Trevor
Miembro Desde 20/01/11
277 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-43, Regan Winter 2011 Miembro de Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 347
