Introducción
This is a step-by-step guide to disassembling and replacing the flash in the Sony Cyber-shot camera.
First locate the appropriate screws for detachment. First locate the appropriate screws for detachment. First locate the appropriate screws for detachment.
  • First locate the appropriate screws for detachment.
Agregar Comentario
Remove the five screws shown using a Phillips #00 Screwdriver.
  • Remove the five screws shown using a Phillips #00 Screwdriver.
  • It is important to put the small screws in a safe location in order to reassemble the casing.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using a spudger, carefully pry open the front casing.
  • Using a spudger, carefully pry open the front casing.
Agregar Comentario
Carefully separate the front casing from the camera body. CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  • Carefully separate the front casing from the camera body.
  • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
Agregar Comentario
Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash. Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
  • Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
Agregar Comentario
Using a spudger, pry the small latch between the lens and the flash open to release the flash. Pull the flash away from the camera. Pull the flash away from the camera.
  • Using a spudger, pry the small latch between the lens and the flash open to release the flash.
  • Pull the flash away from the camera.
Agregar Comentario
Conclusión
Katie McCraw
Miembro Desde 09/03/12
191 Reputación
7 Guías creadas
Equipo
Clemson, Team 1-5, Benson Spring 2012 Miembro de Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 2
Últimos 30 Días: 14
Todo El Tiempo: 1,852
