Partes
No se requieren partes.
It is necessary to first locate the appropriate screws in order to disassemble the back casing. It is necessary to first locate the appropriate screws in order to disassemble the back casing. It is necessary to first locate the appropriate screws in order to disassemble the back casing.
  • It is necessary to first locate the appropriate screws in order to disassemble the back casing.
Agregar Comentario
Remove the found screws with a small screwdriver.
  • Remove the found screws with a small screwdriver.
  • It is important to put the small screws in a safe location in order to reassemble the casing.
Agregar Comentario
Carefully pull the back casing away from the camera.
  • Carefully pull the back casing away from the camera.
Agregar Comentario
The back casing is now removed from the camera.
  • The back casing is now removed from the camera.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Katie McCraw
Miembro Desde 09/03/12
191 Reputación
7 Guías creadas
Equipo
Clemson, Team 1-5, Benson Spring 2012 Miembro de Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,122
