Introducción
This guide will walk you through how to replace the LCD screen of your Sony Cyber-shot DSC-P10 camera.
Partes
No se requieren partes.
Remove the two screws on the top of the camera. Remove the two screws on the bottom of the camera. Remove the rear cover.
  • Remove the two screws on the top of the camera.
  • Remove the two screws on the bottom of the camera.
  • Remove the rear cover.
Agregar Comentario
Peel the strip of black padding off of the screw. Remove the screw. Lift the right side of the screen up, then pull the screen to the right to free the LCD screen.
  • Peel the strip of black padding off of the screw.
  • Remove the screw.
  • Lift the right side of the screen up, then pull the screen to the right to free the LCD screen.
  • Carefully pull on the ribbon circuits to remove them.
  • You have successfully removed the LCD screen!!
Agregar Comentario
Conclusión
Adrian
Miembro Desde 11/10/11
22 Reputación
1 Guía escrita
Equipo
UW Stout, Team 1-1, Zhou Fall 2011 Miembro de UW Stout, Team 1-1, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G1
5 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 1,676
