Saltar al contenido principal
Sony Clie PEG-UX50 Tilt Screen Replacement
Qué necesitas
  1. Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: paso 1, imagen 1 de 3 Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: paso 1, imagen 2 de 3 Sony Clie PEG-UX50 Tilt Screen Replacement, Tilt Screen: paso 1, imagen 3 de 3
    • Take off the screws located on the two sides of the tilt screen.
    • Unscrew the screw located at the tilt base of the screen.
  2. Sony Clie PEG-UX50 Tilt Screen Replacement: paso 2, imagen 1 de 3 Sony Clie PEG-UX50 Tilt Screen Replacement: paso 2, imagen 2 de 3 Sony Clie PEG-UX50 Tilt Screen Replacement: paso 2, imagen 3 de 3
    • Gently remove the back plate of the tilt screen by sliding it upward.
    • With caution, lift the wires from the track in the back plate.
  3. Sony Clie PEG-UX50 Tilt Screen Replacement: paso 3, imagen 1 de 2 Sony Clie PEG-UX50 Tilt Screen Replacement: paso 3, imagen 2 de 2
    • Disconnect the thin USB cable attached to the Integrated Circuit.
  4. Sony Clie PEG-UX50 Tilt Screen Replacement: paso 4, imagen 1 de 2 Sony Clie PEG-UX50 Tilt Screen Replacement: paso 4, imagen 2 de 2
    • Detach the plastic black frame from in between the plate and the LCD.
    • Do not disconnect the display from the board yet.
  5. Sony Clie PEG-UX50 Tilt Screen Replacement: paso 5, imagen 1 de 1
    • Disconnect the thin connector from the face plate using tweezers.
  6. Sony Clie PEG-UX50 Tilt Screen Replacement: paso 6, imagen 1 de 1
    • Quickly release and disconnect the thick cable with your hands.
Conclusión
Follow these instructions in reverse order to reassemble your device.
Rishad R Rai
Miembro Desde 04/28/11
1 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 24
Todo El Tiempo: 2,748
