Introducción
If the lens of the Sony CCD-TR81 video camera cracks or becomes cloudy, replacing it can be costly and confusing. This guide shows how you can easily access the lens assembly to make a quick replacement. You must remove the battery and the outer casing to get to the lens assembly for proper replacement or repair.
Qué necesitas
Open the cassette cover.
Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
2 personas más completaron esta guía.
