Introducción
We turn our devices on and off every single day, and as such, the buttons wear over time. This repair guide will focus on replacing the electrical components controlling the On/Off buttons.
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Agregar Comentario
Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
  • Use a plastic opening tool to pry the cover open.
  • After the the cover is partly open as shown, remove the cover with your hands.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
Agregar Comentario
Use a plastic opening tool to loosen the back cover off the device. Once the back cover is loose, remove it gently by hand.
  • Use a plastic opening tool to loosen the back cover off the device.
  • Once the back cover is loose, remove it gently by hand.
Agregar Comentario
Using a spudger, carefully remove the metal casing that is attached to the ZIF connector.
  • Using a spudger, carefully remove the metal casing that is attached to the ZIF connector.
Agregar Comentario
Unclip the two plastic buttons with the spudger tool.
  • Unclip the two plastic buttons with the spudger tool.
  • The buttons each have a spring under them that will fall off, be careful not to lose them.
Agregar Comentario
Conclusión
Fred Saucedo
Miembro Desde 11/01/13
3 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-12, Maness Winter 2013 Miembro de Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 210
