Introducción
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
  • Use a plastic opening tool to pry the cover open.
  • After the the cover is partly open as shown, remove the cover with your hands.
Agregar Comentario
Detach the board from the ZIF connector using pair of tweezers or by hand. Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
  • Detach the board from the ZIF connector using pair of tweezers or by hand.
  • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
Agregar Comentario
Conclusión
Robert Tam
Miembro Desde 30/01/13
6 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-12, Maness Winter 2013 Miembro de Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 268
