Introducción
If you need to replace your power supply or trigger mechanism, you will have to open up the trigger housing.
Herramientas
Partes
No se requieren partes.
Use the socket wrench to remove the 0.5" length screw from the bottom of the handle. Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
  • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Separate the cord from the handle. Separate the cord from the handle. Separate the cord from the handle.
  • Separate the cord from the handle.
Agregar Comentario
Conclusión
Matt
Miembro Desde 10/10/10
365 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 5-17, Maness Fall 2010 Miembro de Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 1,066
